SAP Addon - ICS Failing to register the partner system via Middleware HCI/CPI
#1
Hi - While creating the Connection from SAP to Concur using the SAP Addon SP06 at the last step we are getting the below error Message
partner system could not be created.
At CPI level there is a request which failed with HTTP Code: 500 Internal server error.
Whereas direct Connectivity that is without Middleware Connection works fine in another environment.
so wondering what could be the issue here, At CPI Standard iFlow is being used and its a passthrough scenario
where the header is being set up with Authorization parameter with token Value and some payload with system add-on, module, and logical system values are being sent
Anyone has any clue on this…
Rajesh
